How easy would it be...
Hey Guyz,
My steering column took a dive, the rod connection from the key to the ignition switch broke.
My question is how easy would it be to hook up a push button switch for the ignition to start the truck ?
Any ideas on how to do this until I can get my column rebuilt / replaced ?
Professional Mechanic
The key is needed for the passlock system. It would be alot more trouble then it is worth for a temporary thing. Also is not done correctly could be a fire hazard.
Hey man if you can pull the steering wheel you can fix this column!! I mean if you have the actual knowledge of removing the steering wheel. Once the wheel and tension spring plate are removed pull the horn cam put aside. (this would be the time to replace that if it doesn't work) Remove the little black screw from the turn signal cam and set aside. Now here you have one of two options. *** you know what you should call me and let me walk you through this*** PM me if your interested!
carid
November 12th, 2015 8:23 AM
pjr7269
Silverado & Fullsize Pick-ups
February 23rd, 2012 3:09 AM
