Old Aug 10, 2015, 11:29 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
no power door lock,no power windows,mirror remote stopped workin
Old Mar 21, 2009 | 7:29 AM
cnterline's Avatar
Default no power door lock,no power windows,mirror remote stopped workin
remote stopped working,put in new battery still not working but right side /passenger door lost all power ? no window,door lock or mirror work
Old Mar 21, 2009 | 12:58 PM
x1cn18's Avatar
what model and year would be good to know and also is it workin from the door switches or what exactly is the prob
Old Mar 21, 2009 | 4:38 PM
cnterline's Avatar
2004 silverado 1500 pick up 2 dr small v8,key fob slowly stopped working ,replaced battery,tried reprogramming that with no luck,also now passenger door locks,window and mirror dont work from either control and dome light does not turn on when pass door is opened,I checked all the fuses everything looks good
Old Mar 21, 2009 | 4:40 PM
cnterline's Avatar
drivers side door lock and window work
Old Mar 22, 2009 | 10:14 PM
x1cn18's Avatar
are all the plugs in good did you do anything at the time that that quit like change batt or anything at all that you can remember
Old Feb 5, 2010 | 12:41 AM
lilestj's Avatar
I have recently had my passenger side door do the same thing. No power whatsoever. Any ideas on what to do? I miss not being able to unlock or roll down the passenger side window!! Please help.
Old Feb 15, 2010 | 4:09 PM
timmysk's Avatar
it sounds like you have a broken wire between the door and dashboard
Old Jun 16, 2010 | 12:53 PM
meaculpa3x's Avatar
I have the same thing happening to a 2003 Avalanche. The key fobs don't work and the passenger side window, locks and mirror don't work. The drivers window switches operate 3 of the 4 windows just not the front passenger. the switch on the front passenger side doesn't work either. Checked the wiring in the boot in the passenger door jam. OH, I just thought, maybe its the wiring in the drivers door jam boot! I'll have to check. This seems to be a common problem though!!
Old Jun 17, 2010 | 9:59 AM
Night Train's Avatar
I am having similar issues with my 97 Chevy Silverado. It's all auto and while cleaning the battery terminals, I noticed the driver side window switch stopped working. So now from the driver side I can't roll down either window. The auto locks work. The passenger side window button works... I checked the switch itself, no issues. Checked the fuse boxes, no issues. I can't think of any wires that could have been
broken in the process. All I did was remove the battery terminals to clean them.
Old Aug 12, 2010 | 10:19 PM
BrianC's Avatar
I have the same problem with a '03 2500HD. Has anyone been able to fix the problem?
