Help?????
Help?????
Hello, I have recently bought a 94 Z71 and the wires to the acuator for the 4X4 have been cut. I can see where 2 of them match up to the harness plug but I still have 1 left. Where does this wire go. Without checking this I cant tell if I need another one or not. Problem #2 is a low idle while in gear. It will almost or will die if your not paying attention. Can someone please help me?
for the idle problem look onside of the throttle body where the cables are and there should be a black screw on the end of one of the cables just turn it until you get it where you want it.
