Notices
Sponsored by: DashLynx
OBD II Trouble Code Po128
Old March 13th, 2010, 8:53 PM
jcolpaert's Avatar
Default OBD II Trouble Code Po128
Getting trouble code P1028. Have replace the ECT. Cleared code and less than week later code back. Temperature guage appears normal (~195 degrees when warmed up). Is there another temp sensor somewhere as the code will clear on its own if the outside temp is below 45 degrees. Manual states that ECT acts as both the temp sending unit and input for PCM. What should next step be?
2006 Silverado, 4.3L V6 with approximately 85K.
Last edited by jcolpaert; March 13th, 2010 at 9:52 PM. Reason: Adding truck information
Old March 13th, 2010, 8:55 PM
xpeder's Avatar
year make model of truck
Old March 13th, 2010, 9:04 PM
maxxman04's Avatar
yeah, we're gonna need the vehicle specifics. typically tho, there is a sending unit for the gauge, and another sensor for the ecm.
Old March 13th, 2010, 9:43 PM
Professional Mechanic
MDTAHOE's Avatar
Replace the t-stat. 99% of the time it takes care of the problem.
Old March 23rd, 2010, 12:10 PM
jcolpaert's Avatar
Thanks. Thermonstat replaced and problem solved. Suspect old thermostat was opening too soon. Thanks again!
Old March 23rd, 2010, 7:41 PM
per
per's Avatar
Default p0128 code
replaced thermo and added coolant still have ck eng light
Mehthiro
May 20th, 2020 3:14 PM
lovesmonica
March 22nd, 2011 8:02 PM
Christie08
July 6th, 2009 3:38 PM
rsaz
September 6th, 2008 8:58 AM
kil0
June 4th, 2007 9:11 PM
Quick Reply: OBD II Trouble Code Po128
