Notices
Sponsored by: DashLynx
Old July 29th, 2015, 12:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
power loss
Old October 1st, 2014, 9:33 PM
jcwclm's Avatar
Default power loss
I was towing my jeep this weekend and my truck acted up 2 or 3 times. I would lose power and have to come to a stop. I had my pocket scanner with me. It showed p0300, p0131, and p0151. I believe it also backfired once. I've also had issues with it idling only when in drive/reverse but not in n/p. Not sure if this is related. Thanks for help in advance.
99 Silverado 2500 6.0
Old October 6th, 2014, 2:15 AM
jcwclm's Avatar
Ttt bump
Old October 8th, 2014, 12:41 AM
89scottsdale's Avatar
We had a GMC that came in few months ago.. it was a firefighting rig that ran the nastiest fuel those guys could find. it misfired, ran horrible, pretty much what your describing. i got misfire codes and that was it. i tried plugs and wires and the back cylinders were super fowled. ended up being a fuel pressure regulator that fixed the problem, they tend to be a common failure on these trucks.
Old October 8th, 2014, 12:43 AM
also check your 02 sensors.. those codes lead to sensor failure.. which id bet my money on.
Old October 8th, 2014, 9:47 PM
jcwclm's Avatar
I've already checked fuel pressure and it seems the fpr is working fine. Would one bad o2 sensor cause both codes?
Old October 9th, 2014, 12:43 PM
Bad 02 sensor would cause these issues.
Old October 9th, 2014, 12:46 PM
The first oxygen sensor closest to the motor is having a issue. Check the connections. That sensor failed and is causing the issues you at having.
Old October 17th, 2014, 3:47 PM
jcwclm's Avatar
It has 2 upstream o2 sensors. How do I determine which is bad?
Old October 28th, 2014, 7:30 PM
jcwclm's Avatar
Anyone?
Old January 14th, 2015, 3:03 PM
jcwclm's Avatar
Bump again.....................................
trbball44
December 21st, 2006 4:15 PM
jesse_t_green
October 8th, 2006 12:42 PM
mnkstock01
June 13th, 2006 1:56 AM
charlieroc
April 13th, 2006 1:03 AM
Quick Reply: power loss
