Notices
Sponsored by: DashLynx
Old July 24th, 2015, 6:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community expertsBrowse all: Engine and Powertrain
Print Wikipost
Radiator Drain Valve (petcock)
Old March 21st, 2010, 12:34 PM
JK23112's Avatar
Default Radiator Drain Valve (petcock)
I am soon going to flush & replace my coolant/anti-freeze in my 2004 Silverado 1500 {5.3L V8}. When I looked under the hood, I did not see the drain valve. Is it hidden behind the fan shroud or something? Jeez!
I don't much like it when things are not where I am accustomed to seeing them on other vehicles. Where is the dang thing?
** En vino veritas. **
Old March 21st, 2010, 2:10 PM
s34n's Avatar
check at the bottom of the radiator on either side. should be at the lowest point of gravity. if you cant find it. invest in a chiltons manual or disconnect your lower radiator hose.
Old March 21st, 2010, 3:08 PM
JK23112's Avatar
Yep; I may have to go that route. The hose doesn't look as though it would be very hard to remove - and the clamp is acessible.
Thanks!!
Old March 21st, 2010, 3:12 PM
s34n's Avatar
no problem. make sure when filling back up to burp the system to get all the air pockets out of the lines.
domano 68
January 24th, 2014 7:26 PM
csbacct
July 26th, 2011 6:59 PM
TomS209
October 6th, 2009 2:13 PM
julian734
Astro
March 29th, 2008 12:35 AM
peterz
April 22nd, 2007 8:05 PM
Quick Reply: Radiator Drain Valve (petcock)
