Old Jul 27, 2015, 2:44 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Radio locked
Old Oct 20, 2013 | 4:49 PM
alan07's Avatar
Default Radio locked
I just bought a delco radio for my 05 1/2 t. When i plugged it in it said "locked" on the display.
Does anyone know how to unlock these radios ???
Any help is greatly appreciated.
Alan
Old Oct 20, 2013 | 4:59 PM
I found this with a quick Googling... might try it and see if it works...
Let us know if it does.... it came from Here is how to unlock Delco Theftlock radio that displays "LOC" - Diesel Place : Chevrolet and GMC Diesel Truck Forums
GM DELCO THEFTLOCK RADIO UNLOCK CODE:
1. Press and hold presets 2 and 3 for about 5 to 10 seconds until you
get 3 digits on your display. This is the first 3 of 6 digits you will
need, so write 'em down.
2. After doing step one and writing down the code, immediately press
the
AM/FM button to get the last 3 of the 6 numbers you'll need, and write
'em down. (if you wait too long between steps 1 and 2 and the LOC code
displays again, just start over).
3. Call this number, it's a prerecorded message, so don't worry about
having to talk to anyone...1-800-537-5140. The voice will ask if
you're
calling for Chevy, Pontiac, Cadillac, etc... When you here him tell
you
to press "2" for Pontiac, press 206010 and hit the # key. He'll ask
you
for the 6 digit code that you've written down. Enter that and press
the
* key. He will then give you a code, and the option to get additional
digit codes, but one should be sufficient.
4. Follow the normal procedure in your owners manual for unlocking the
radio with your new code...press the hour set button on your radio
until
you get the first two numbers of the code, then press the minute set
button until you've entered the last two numbers. Immediately press
the
AM/FM button once the correct code is entered and the code SEC or
"secured" will be displayed on the display screen. Now, just turn the
radio on, and your ready to roll.
There is an additional step you can take to remove all codes from the
radio and start from scratch by entering your own personalized 4 digit
code so that it won't get you in a pickle again! Just repeat step 4
and
you should get a display screen that reads ---. This means the code is
out, and you can now program your own code. Of course, once you
receive
the 4 digit code from the GM recorded message, just keep it in a safe
place, because you can use that same code again and again should you
have any more problems with it in the future. Good luck, and yes, it
does work.
Vanilla Skywalker
Apr 9, 2024 6:12 PM
rcs3x7
Jul 23, 2015 8:26 AM
tsp0054
Feb 7, 2013 11:03 AM
aeropatr82
13
Oct 18, 2009 1:46 AM
deecee82
May 21, 2007 9:42 PM
