Notices
Sponsored by: DashLynx
Old July 29th, 2015, 12:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
reset "change engine oil" reminder
Old August 18th, 2006, 10:05 PM
celticchevychic's Avatar
Default reset "change engine oil" reminder
Got the oil changed, but usually the tech's reset the sensor for me. This time they didn't and the message "change engine oil" is still coming up. I've got an 03' LS and I don't have the fancy DIC, so I can't reset it there. I know it has something to do with pumping the brake pedal, but beyond that, I need some help. Thanks for helpin' a girl out.
Old August 19th, 2006, 12:36 AM
NCHEVYHEVN's Avatar
Default RE: reset "change engine oil" reminder
Turn the key on but engine off.
Press the gas pedel fully 3 times
Then it will say "change engine oil" and then it will say "oil life reset"
After that cycle the key on and then back off.
Old August 25th, 2006, 4:01 PM
I tried this with no luck. I tried at different times after I turned the key on, but I'm not having any luck. I'm not really the dumb*** it may seem, honest. [sm=loser.gif]
Is it possible that I'm just doing something wrong?
Old August 25th, 2006, 6:24 PM
kcb37's Avatar
I don't know if this will work or not, but have you tried to discconect the battery yet? You should only have to have it off for a min or two, but I suggest 5 to 10 just to be sure.
Old August 25th, 2006, 8:05 PM
carpenterbill's Avatar
Just make sure you fully depress and fully release the pedal 3 times, works everytime for me.
Old August 25th, 2006, 11:02 PM
KissMySS's Avatar
Turn the ignition key to the RUN position.
Fully push and release the accelerator pedal 3 times within 5 seconds.
If the Change Oil Soon light flashes, the system is resetting.
Start the vehicle.
The oil life will change to 100%.
If the Change Oil Soon light comes back on, the system has not reset.
Repeat the procedure.
works every time !
Old January 29th, 2007, 3:56 AM
best49erfan's Avatar
I have recently changed my oil and did the reset, but everytime i turn my truck on, it shows back up on the DIC.
electrichorseman
Express & G-Series Vans
January 27th, 2015 9:51 AM
Misfit Toy
May 31st, 2011 3:28 PM
ramman7777777
July 24th, 2007 7:41 AM
RonnusTwo
August 17th, 2006 12:38 AM
Quick Reply: reset "change engine oil" reminder
