Notices
Sponsored by: DashLynx
Service Stabilitrak, Traction Control, LIGHTS come on when I let off the gas
Old January 22nd, 2016, 10:52 AM
colton222's Avatar
Default Service Stabilitrak, Traction Control, LIGHTS come on when I let off the gas
Service Stabilitrak, Traction Control, LIGHTS come on when I let off the gas, but Service Stabilitrak, Traction Control lights turn off when i give it gas.
OBD2 codes showing
P 0107
P 0106
P 0113
I replaced MAP sensor twice each time i did the truck wont start. But when I DISCONNECT MAP SENSOR TRUCK STARTS and RUNS GREAT, BUT Service Stabilitrak, Traction Control CHECK ENGINE lights come on. I should mention I just had a brand new crate motor put in. I have put only 300 miles on new motor so far and Service Stabilitrak, Traction Control,CHECK ENGINE LIGHTS have been on ever since i got new engine put in. Please help. Thanks
Old January 22nd, 2016, 6:39 PM
Armyvetjohn's Avatar
Sounds to like you might want to Check the grounds behind both heads make sure they are hooked up. Also make sure the installer did not pinch the wire harness between motor and Transmission ...
Old January 22nd, 2016, 8:19 PM
what ya driving...year engine etc.
Old February 13th, 2016, 6:15 PM
wehowardjr's Avatar
Would like to add that I recently started getting the SERVICE STABILITRAK and ABS warning lights when I tapped the brakes or sitting at a stop light. It ended up being the brake light switch. Cost me $21.99 at Autozone and fairly easy to replace.
