Notices
Sponsored by: DashLynx
Old August 4th, 2015, 3:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
theft-deterrent system HELP...
Old January 3rd, 2015, 7:56 PM
  #11
bmh
bmh's Avatar
It began with a failed remote start and several more attempts. We have figured that the theft system engaged. We have determined the fuel pump does work but the electronics are not letting power to be properly connected to it {anti-theft] ON A 2009 GMC SIERRA
Old March 10th, 2015, 12:16 PM
  #12
sjhaux's Avatar
Default same problem
did u find any out I got same problem
Originally Posted by twins225
i have a 2008 silverado. i just went to start it and the security anti-theft lock is armed on the truck. i can't start the truck at all. i called onstar to have them help me trouble shoot and they just told me to let it sit for 15 minutes and then try again with a spare key. that still didn't work. they say i have to have the truck towed to the dealer to have it reset. is there anything else i can do to get the truck to start????
Old April 2nd, 2015, 1:29 PM
  #13
jorgem's Avatar
Hi did you find that your remote starter was causing your "service theft deterrent system" message/issues? I'm currently having the same issue. My 07 suburban won't start with a fully charged battery. (Getting same massage: "service theft deterrent system").
Old June 5th, 2015, 1:17 PM
  #14
mrperry0007's Avatar
Default Theft system
Originally Posted by Papa@MamaPassarelli.com
Guess you were lucky. I took both positive and negative cables off and held them together for a minute for my Silverado and still have the problem. Guess I'm going to have to have it towed.....
Try turning the key on until the yellow lock goes out on the instrument panel about 10 minutes. Turn key off and do it again 2 more times then after 3 cycles, pull key out and put back in and it should start.
Old July 8th, 2016, 1:24 AM
  #15
Jrigger's Avatar
Is there a recall on the 2007 gmc for the theft deterrent? My truck won't start and I have tried everything on this page to try and reset it. I think gm should have to foot the bill for this kind of hassle !
Old August 25th, 2016, 10:21 AM
  #16
mikeprior_@hotmail.com's Avatar
Default What ended up getting done?
What was the part that needed to be replaced?
Old November 19th, 2016, 5:49 PM
  #17
Nandito Cha's Avatar
Default Service theft deterrent system
I tried this on my 07 Impala but didn't have much luck. I'm still having the same light on "service theft deterrent system". My car has been like this for about a week now. If anyone can help I would really appreciate it
Old March 25th, 2017, 11:22 PM
  #18
Kimberly Thomas's Avatar
Default This is the only thing that helped me
"Try turning the key on until the yellow lock goes out on the instrument panel about 10 minutes. Turn key off and do it again 2 more times then after 3 cycles, pull key out and put back in and it should start."
Old August 21st, 2017, 2:04 AM
  #19
Melissa Lee's Avatar
Originally Posted by Cindy Routon Tyler
I left the lights on my car last night and battery is dead. I have messed with it so much I think I've done something to the theft deterrent system. I cannot get the keys out of the ignition (yes we tried wiggling the gear shift & the steering wheel, etc.) My key fob does not work, I've pushed those buttons. I cannot get to the battery as it is in that back end of my car & I can't get the hatchback to open up (it's locked). Anybody have any suggestions?
look under the ignition on the steering colum there is a hole that you can use a screwdriver or something to push a button that releases your key.
Old November 28th, 2017, 10:46 AM
  #20
knjkav's Avatar
Default Key stuck
​​​​​​If e battery is dead the key won't come out. Try hooking up a jump box or cable from another car then you can take the key out. I found out the battery posts in the engine worth a crap hooking straight to the battery in trunk gives you better connection.
Quick Reply: theft-deterrent system HELP...
