third brake light wire for topper
Old Feb 3, 2012 | 10:11 PM
Puller45's Avatar
Default third brake light wire for topper
I'm working on my daughter's 2005 silverado LTZ. Does Chevy provide a wire near the rear end to tap in a third brake light for a topper? If so does anyone know what color it is? Location? Thanks in advance for any help.
Old Feb 3, 2012 | 10:23 PM
Zackman1995's Avatar
the wires should be red. i have a 2003 z71 and there basically the same truck. if you have a plastic bedliner, you should be able to pull it out there at the end on the drivers side and you should be able to tap into the brake light right there at the end. thats what i did with mine. then i just spliced it into a plug so when i decide i want the topper off i just unplug it. post back with any questions but hopefully this will help.
Old Feb 3, 2012 | 11:48 PM
Puller45's Avatar
does your topper light blink with one of your turn signals?
Old Feb 4, 2012 | 10:03 PM
grumpychevy's Avatar
No, tap into the brake light inside of your taillight housing. Use bullet connectors or a plug so you can disconnect to remove the cap.
Classical Glass
Aug 10, 2010 9:17 PM
biglg
Feb 22, 2010 8:37 PM
mcagney014
May 28, 2007 1:34 PM
JJ4NU83
Mar 14, 2007 6:54 PM
matador
Jul 6, 2006 3:23 PM
