Notices
Sponsored by: DashLynx
Want to build street/strip 350 silverado...what does the 350 need? Heads? Cam? Intake?
Old June 18th, 2006, 8:18 PM
5.0stang's Avatar
Default Want to build street/strip 350 silverado...what does the 350 need? Heads? Cam? Intake?
Also post track times...
What is the best heads, cam, intake in your opinion (money not a problem) to put on a street/strip 2wd Silverado?
What generations do the silverado's break down too?
I like the early to mid-90's looking model and that is what I'm looking at getting...
Any ideas?
Thanks guys/gals!
Old June 18th, 2006, 10:47 PM
Chevrolettruckman8's Avatar
Default RE: Want to build street/strip 350 silverado...what does the 350 need? Heads? Cam? Intake?
ditch the computer crap and run an older carborated engine, and geta 400 crank, and intake and carb really depends on what you want to do but there is a starting point for you, it all depends on if your looking to go for 300HP or upto 450+HP
Old June 21st, 2006, 1:16 AM
5.0stang's Avatar
Any way I could due it EFI? What was the first year of EFI? Thanks for the response.
I would like a combo that could drive fine on the street...no crazy stall...and hit the track...kind of a 50/50 truck...
Old June 16th, 2022, 7:46 AM
Tommytunes's Avatar
Default Motor output
  • I have a gen2 350/250 crate motor. The bottom end is stock. It has 750 d/f holly, edelbrock proformer intake, hooker headers, hei, proconp 190/64cc 272 springs 202/160 valves, crane roller rockers, summit push rods, lunati #10120703 hyd. Flat tapper cam, 489/504 lift summit timing chain & gears. Also has 4” cold air intake. Does anybody have any idea what compression, torque, & hp this set up would make??
jmfranklin617@gmail.com
May 24th, 2016 5:27 PM
robert4747
Engine Building & Overhauling
May 13th, 2016 5:01 PM
78maroboy
Camaro
April 27th, 2013 9:14 AM
chevyboy1993
August 21st, 2012 9:01 PM
beefcake9987
July 28th, 2012 2:48 AM
Quick Reply: Want to build street/strip 350 silverado...what does the 350 need? Heads? Cam? Intake?
