07 Throttle body cleaning
Old November 17th, 2009, 1:06 AM
black07hoe's Avatar
Default 07 Throttle body cleaning
Anybody have a simple write up on cleaning the TB on a 07 up ?
Dealers want too much.
Old November 20th, 2009, 1:06 AM
black07hoe's Avatar
over 50 views no replies....let me start it....
1. Take engine cover off
maybe someone can chime in on the rest
Old November 20th, 2009, 8:27 AM
SabrToothSqrl's Avatar
Default well
i had 285,000 on my old tahoe and never did this..?
https://www.mobiloil.com/usa-english...le_bodies.aspx
Printable version:
https://www.mobiloil.com/usa-english...tle_bodies.htm
Old November 20th, 2009, 8:49 PM
rubrhammer's Avatar
You probably have drive by wire and can't actuate the plate manually is why you're asking.
I haven't tried cleaning a DBW tb yet so I'm going to offer a suggestion. Get a helper to set in the car with the key in the run position engine OFF and have helper actuate the gas pedal and see if it will move so you can spray and wipe with shop solve or similar carb cleaning solution.
I do this operation on my 2000 Silverado a couple of times a year when it starts to feel sticky when easing off of idle.
Bob
Old November 21st, 2009, 11:03 AM
Why do you think it needs cleaning?
Old November 21st, 2009, 12:12 PM
black07hoe's Avatar
At about 85k miles, it threw a "check smog system" light. Took it to the dealer and they basically said it needed TB cleaning. Doorknobs at dealership said to have it done every 15k miles which I doubted. I have 97k now and every time it hesitates a bit, i get to thinking.
Old November 21st, 2009, 12:27 PM
black07hoe's Avatar
Btw, I use Chevron and pop in the chevron CFS cleaner every 5-7k.
Old January 10th, 2014, 7:27 PM
rvilla's Avatar
This video shows an 07 sierra, pretty much identical to my tahoe.
I'm gonna go out to the shop and do this as soon as the rig cools down. I've been having a "service traction control" problem. hard shifts and TB position sensor errors.
In this video it doesn't depict a method of cleaning the sensor in the TB sensor housing, I've heard of people having the housing seal go bad and get the sensor wet and cause all sorts of problems.
Old January 10th, 2014, 8:38 PM
Welcome to the forum, and thanks for the how to video...
I did a write up a while back also located at this link...https://chevroletforum.com/forum/tah...-gmt900-54328/
in2pro
16
August 10th, 2022 12:36 PM
niceguy88
Uplander
September 23rd, 2011 8:49 PM
RJK
January 21st, 2011 11:07 AM
Rod Man
Silverado & Fullsize Pick-ups
23
March 22nd, 2008 3:54 PM
firered89
August 16th, 2006 12:26 AM
Quick Reply: 07 Throttle body cleaning
