2003 heated seat turn on/off randomly
Former Vendor
Do they turn off randomly while in use, or intermitantly not work. IIRC, if the seat belt is not connected, the seat heaters will not operate on that year.
Kevin Cassimore
Kevin Cassimore
Kevin,
They just come on while I'm driving with the seat belt on.
You can see the lights on the heat switch go on for about 30 seconds and then go off on their own. It does this over and over.
Is there a sensor in the door I can replace??
2004 Suburban w/ Seat Heater problems
I have the same problem, although it usually just turns off after 45 seconds. The dealer wants $900.00 to fix the problem and says the capacitor is failing? WTF?? There has to be a cheaper fix. My fuses look good, but something is tripping the heater. I live in Houston and only use the heaters about 2 months out of the year. Any help is appreciated.
Mr. Vann
Silverado & Fullsize Pick-ups
November 25th, 2009 7:24 PM
cactusjack
11
May 7th, 2008 10:03 PM
