Gauges reset in cold weather
Old Sep 24, 2012 | 11:48 AM
Creoden's Avatar
Default Gauges reset in cold weather
Hey All,
I've got a 2008 Tahoe that works great except for one annoying problem, the instrument cluster resets continuously in cold weather (below 12c/54f), it only stops once it's warmed up.
Has anyone seen this before, and if so is there any easy fix, or do I have go get a whole new instrument cluster?
Thanks!
Old Sep 25, 2012 | 7:33 AM
Welcome to the forum,
I would try re-seating the connections to the instrument cluster first, I suspect its a poor connection and not a bad IP.
Old Oct 2, 2012 | 11:47 AM
Official GM Rep
Originally Posted by Creoden
Hey All,
Thanks!
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Creoden,
I also suspect a connection issue. Have you been able to resolve this issue?
Louis
GM Customer Service
Old Oct 2, 2012 | 5:40 PM
hicksvilleshick's Avatar
might be worth running new ground wires too.
:chug:
Old Oct 12, 2012 | 12:36 PM
Creoden's Avatar
Sorry, been really busy, just got a chance to remove the instrument cluster and reseat the connection, it still does it after the trucks sat overnight and the cluster has gotten cold
jlenkows
Dec 8, 2006 8:27 PM
TexasTahoe
Dec 5, 2006 10:23 PM
trbball44
Nov 23, 2006 1:15 PM
fredster
Nov 13, 2006 3:14 PM
