Drivers seat switches reversed
Old August 11th, 2012, 10:55 PM
shadowrider05's Avatar
Default Drivers seat switches reversed
I have an 04 suburban that the switch gear seems to be reverse on, to move the seat forward the switch is pushed back, and to raise the back part of the seat the switch is move down (and vise versa). I had an 03 that did the same thing, any advise?
Old August 12th, 2012, 8:56 AM
Get a new switch.
Old August 12th, 2012, 3:01 PM
kevinkpk's Avatar
Originally Posted by oldchevy
Get a new switch.
Same here. Those things cheaply built.
Old August 13th, 2012, 12:23 AM
Maybe the connector on the back is reversed although they're usually polarized. Only other thing if the switch is deemed OK would be to rewire the polarity.
Old August 14th, 2012, 10:21 PM
Ronaldo's Avatar
Default Just had that problem fixed
My 2004 Suburban had the same problem. You push the switch forward and the seat goes back, push it up and it goes down.
The module that controls the seat had to be reprogrammed. This is a dealer only fix. One dealer wanted $105 to do it. Another wanted $59 to do it.
Since the diagnostic was the same price as the fix, I had them do that too. There is a TSB on this problem.
#PIT3598: Power Seat Switch Works in the Opposite Direction - keywords AN3 driver electrical intermittent memory module move operation recall reverse RKE - (May 26, 2005)
Subject:
Models: 2003-2005 Cadillac Escalade, Escalade ESV, Escalade EXT
2003-2005 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2003-2005 GMC Sierra, Yukon, Yukon XL, Yukon Denali
with Seat, Front Individual (Non BKT) (RPO AN3)
2003-2005 HUMMER H2
with Seat, Front Bucket Deluxe (RPO AR9)
Old August 15th, 2012, 1:11 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> "Ronaldo" offers a possible solution. The driver seat module may need to be reprogrammed. Please contact your local certified technician for additional information.
Please keep us posted.
Louis
GM Customer Service
Dbuseyiii
Silverado & Fullsize Pick-ups
September 20th, 2021 9:26 AM
hub_cap
April 8th, 2013 6:49 PM
jimmys57chevy
Express & G-Series Vans
August 22nd, 2012 8:45 PM
fritzlovesmary
December 17th, 2006 3:32 PM
edg
July 19th, 2006 12:27 PM
Quick Reply: Drivers seat switches reversed
