Now have P0101 code
Old March 21st, 2010, 8:02 PM
  #11
PastorK's Avatar
I just didn't look hard enough
MDTahoe said it first, but sahwnvw typed it out
https://chevroletforum.com/forum/s-10-blazer-20/computer-reset-19833/
<table border="0" cellpadding="0" cellspacing="6" width="100%"><tbody><tr><td class="alt2">
</td> <td nowrap="nowrap">
</td> <td width="100%">
</td> <td valign="top" nowrap="nowrap">
</td> </tr> </tbody></table>
<hr style="color: rgb(0, 0, 0); background-color: rgb(0, 0, 0);" size="1"> <!-- / icon and title --> <!-- message --> Its called an OBD II Drive Cycle. its not a matter of how many miles you drive, but like MDTAHOE stated, its a matter of accelerating and decelerating properly. The exact procedre is below
An OBD Drive Cycle:
After you've "fixed" an emissions problem on your OBDII-equipped vehicle, you should perform what's called an "OBDII drive cycle." The purpose of the OBDII drive cycle is to run all of the onboard diagnostics. The drive cycle shold be performed after you've erased any trouble codes from the PCM's memory, or after the battery has been disconnected. Running through the drive cycle sets all the system status "flags" so that subsequent faults can be detected.
The OBDII drive cycle begins with a cold start (coolant temperature below 122 degrees F and the coolant and air temperature sensors within 11 degrees of one another).
NOTE: The ignition key must not be on prior to the cold start otherwise the heated oxygen sensor diagnostic may not run.
[*]As soon as the engine starts, idle the engine in drive for two and a half minutes with the A/C and rear defrost on. OBDII checks oxygen sensor heater circuits, air pump and EVAP purge.[*]Turn the A/C and rear defrost off, and accelerate to 55 mph at half throttle. OBDII checks for ignition misfire, <nobr style="color: darkgreen; font-weight: normal; font-size: 100%;" id="itxt_nobr_7_0">fuel</nobr> trim and canister purge.[*]Hold at a steady state speed of 55 mph for three minutes. OBDII monitors EGR, air pump, O2 sensors and canister purge.[*]Decelerate (coast down) to 20 mph without braking or depressing the clutch. OBDII checks EGR and purge functions.[*]Accelerate back to 55 to 60 mph at ¾ throttle. OBDII checks misfire, fuel trim and purge again.[*]Hold at a steady speed of 55 to 60 mph for five minutes. OBDII monitors catalytic converter efficiency, misfire, EGR, fuel trim, oxygen sensors and purge functions.[*]Decelerate (coast down) to a stop without braking. OBDII makes a final check of EGR and canister purge.[/ol]
Last edited by PastorK; March 21st, 2010 at 8:10 PM. Reason: To give proper credit.
gearhead8853
Avalanche
June 28th, 2014 10:30 AM
gearhead8853
June 28th, 2014 10:29 AM
scrnchr
January 26th, 2012 10:43 AM
jtlonghorn
Silverado & Fullsize Pick-ups
August 24th, 2011 8:20 AM
cham88
January 30th, 2011 11:48 AM
Quick Reply: Now have P0101 code
