Welcome to Chevrolet Forum - Chevy Enthusiasts Forums
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Tahoe & SuburbanThe power, space, and brutal towing ability make the Tahoe and its longer sibling, the Suburban, arguably the best full size SUV's on the market today.
I have searched the forums pretty well and have not found anyone else with the exact same problem, so here goes.
2002 Z-71 Tahoe
My driver's side power door lock does not work at all. It will not lock/unlock any of the doors. No movement at all. The passenger side will lock/unlock all of the doors except the driver's side. When I put it in drive all doors except the drivers will lock and when put it in park all doors will unlock except driver's door. No movement at all. Also, the power mirrors do not work. All windows work fine from all doors.
I have checked all the fuses I know to check in the door jam and under the hood. Didn't appear to be any related fuses under the dash.
Thanks!!
Register today for free or log-in if already registered to remove this ad!
sounds to me the drives side door switch isnot working and preventing the door lock solenoid from working.
pull the switch out and try cleaning it up and reseating the connections
I have never worked on any component of a door lock system before. Can you be a a little more specific as to where the switch is and how to get it out? Doesn't sound too hard.
Thank you very much....this has been giving me headaches for a couple of weeks now.
No luck on cleaning the door lock switch. I called the Chevrolet dealership to ask about a new door lock switch. Of course, way over priced and non-refundable. Any other ideas?
Are you getting 12V to the switch. Sometimes one or more of the wires w/ break where it passes from the body to the door. If you are getting 12V to the switch, then you need to jumper 12V to the lock solenoid to see if it's working.
__________________
2010 Sheer Silver Tahoe LTZ (all options but sunroof, power boards), GM (body color flaps, rear console, 3rd row mat, 2-Way Remote, chrome gas door), Eagle Eye LED tails, SLP dual tip exhaust, Silver bow-ties/rear wiper, Catch-All mats, AlphaTherm washer fluid heater, Putco chrome mirror covers, silver calipers, board chrome trim, tint, GMPP Major Guard
Just need to trace back the wiring and find where you're losing the 12V. Could be a relay. Is it getting 12V? It's probably downstream from the switch so it won't be.
__________________
I kinda had the same problem with my 2001 Tahoe. My passenger rear didn't lock/unlock. The locking relaywas getting power but something was preventing the actual rod to lock the door. I pulled off the door paneland checked out the switch which was fine. The actual door rod was broken near the latch and had to be replaced. It was a pita!
