rear auto level issue
ok,this is an 07 suburban LTZ with air leveling, I need help!! I have replaced the entire suspension system within the last year, front struts and mounts, rear air shocks, and compressor, last August, I had one rear rubber boot take a crap and replaced that shock and all was fine, now the passenger side rear air shock ( new shock after the boot issue) now is just stiff! the compressor runs at start for a few seconds then stops, the driver side rear feels fine but the passenger does not feel as if it deflates or releases the air,I took off the air line and got a quick release of air, any suggestions? no dash lights or warning lights
Former Sponsor
Coil Conversion Kit
Conversion kit will fix your current and future issues but you would want to stick with the rear air assisted shocks if you tow or carry a lot of cargo. Call Arnott tech support to see if they have heard of this issue. 321-868-3016 or 800-251-8993.
https://www.arnottindustries.com/par...11_pid172.html
Also, you can use code GMSAVE10 to save up to 10%* off the retail prices on Arnott® replacement air suspension products for your GM vehicle. You can place your order online at the Arnott Web Store or by calling Arnott Customer Support at 1-800-251-8993 X 804 Mon – Friday from 8:00 AM to 7:00 PM ET. Orders placed by 2:30 ET are typically shipped out the same day.
*Max savings $75 per order, not valid with any other offer or on compressors, shipping, taxes or core deposits (if any).
