97 chevrolet suburban 97 has spark, has fuel pressure, won't start
Old February 5th, 2017, 5:46 PM
ElectricHippie's Avatar
Default 97 chevrolet suburban 97 has spark, has fuel pressure, won't start
I have a 97 suburban, with the Vertec engine, that I drove to my shop, parked for 5 days in the rain, and now it won't start. It has spark on all 8 cylinders. Fuel pressure is at 63 psi and pouring fuel down the throttle body had no effect. The only trouble code is a bad oxygen sensor, which I don't believe would cause a no start. The security light does not illuminate and three ten minute cycles (in case the light is bad) had no effect. Any ideas on what else to check? Thank-you in advance for any suggestions.
Old February 5th, 2017, 6:56 PM
kevinkpk's Avatar
How many miles? Could be a plugged cat.
Old February 6th, 2017, 2:37 PM
While checking plugs and re-checking spark, I realized the spark on 2 cylinders was intermittent. New cap and rotor did the trick.
Old February 9th, 2017, 9:11 AM
falconbrother's Avatar
Thanks for the update.
