Need a 12 volt and Ground source
I recently installed a rosen 1210 (Great Unit) in my 2013 Tahoe and also connected a rear camera. The unit has been working well, but the camera works intermittently. I initially powered the camera by tapping into the reverse light, so when the vehicle was in reverse the camera activated. I assume this may have contributed to my camera not working so I decided to connect to a power source in the Left I/P Junction box. Here' s the problem. My research indicates port x14 pin 7 is 12v and pin 1 is ground. When I removed the cover of the I/P junction box I noticed port x14 only has pins sticking out but no plug. Question, is there a plug I can purchase to connect my camera power leads to and plug into this port to get the power I need. The number on the I/P box cover is Delphi part 20813087_N2 if this helps.
Thanks, I never considered that. If I use the lighter in the rear console, how do I access the wires? Would I need to remove the entire console?
I believe I have it figured out. Did some research and found out how to remove the control panel on the back of the center console. Turns out it pops out after the console top is removed. I will connect at this point.
Thanks for for the suggestion.
I spliced into the rear lighter, but this is constant even when the vehicle off. Decided to disconnect and seek out another source. Preferably RAP somewhere.
