2004 Tracker 2.5L Cutting Out when warm
Hope someone has some ideas. I have a 2004 2.5L tracker with 240,000 KM and it seems to cut out when it is warmed up like you turn the key on and off really fast. I am not getting any codes and I took it to a garage and no codes there either. Mechanic thinks a module under the dash must be the problem but do not see anything obvious. Wondering if anyone else has had this problem before??
2004 Tracker 2.5L Issue
Cuts out only when up to operating temperature runs fine when cold, could not find any obvious wiring issues seems a bit worse at idle but will still cutout at normal speeds, cuts out like turning the key on and off really fast.
Ended up taking this to a shop and the PCM was the problem, opened up the old one and there was all kinds of corrosion, even though it is under the glove box there must be lots of moisture in there. Going to take a closer look to make sure there are no leaks from the A/C system as well that would cause some of this. Hope this helps someone else out if they are having intermittent electrical issues with a Chevy Tracker.
