No bells or chimes
No bells or chimes
I only have one leg, so I have been riding in a wheelchair behind the front seats and only today realized that there was no sounds from anywhere. Even the turn signals don't make a clicking sound when turned on. Is there some way the sounds can be turned off? It just baffels me.
Hi- I don't know of a way to turn off all of the sounds....
By any chance does the van have an aftermarket radio? All of the sounds go through the radio and you need a special adapter if you install an aftermarket radio in order to still have the sounds. I replaced the radio in mine...that's how I know about it. There's also a volume control on the adapter so if it has one installed maybe the volume control is turned all the way down. Unfortunately that will require you to remove the dash by the radio. But first things first...
Now I'm with you...I'm baffled too.
Here's a thought: Blinker sounds, etc come out of the drivers side speaker on the door. Turn on the radio and using the balance and fade , have the music just come out of the drivers side door speaker...if the speaker isn't working that might explain it. Honestly if this isn't it I'm not sure what else to suggest short of a wire being accidentally cut during the conversion and I'm not thinking that's the case. I have seen cases where the wires going to the door get broken from the constant flexing where they go into the door.
I've seen a bunch of them on the road but I'm not really familiar with the BRAUN vans so I can't say what they do to it. Let me know how your speaker test works out. Good Luck!
Bells and Chimes
I tested the speaker as you suggested, and the driver side was equally as loud as the right side. Guess I will be taking the radio out but I sure dred it.
Bummer - Sorry I couldn't provide a quick fix for you. I've taken the radio out...not as bad as it looks. Just take your time. Scariest part is prying off the radio bezel...go gently. Good Luck!
Bels and Chimes
Hey 442 dude, I was wrong about ythe speaker. We took the door sideing off, and the speaker was unpluged. Pluged it in and away we go with sound and music. Ever heard of anyone installing new speakers? Looks like it would be impossble. Thanks for all the help.
YAHOO!!!!So great to hear you figured it out!
All the best,
442
40lenny
Silverado & Fullsize Pick-ups
16
January 5th, 2017 6:10 PM
wysilverado
May 3rd, 2012 1:52 PM
undertaker
October 4th, 2009 12:26 PM
