Problem starting Venture '97
My van just stop starting. It got me stalled on the road. The engine just stopped suddenly. When I tried to start it, it wont. I dont hear the Fuel Pump humming when I turned the key to ON position though the engine is cranking when tried starting it. I changed the fuel pump, fuel pump relay and fuse but with the same result. Still, I think the fuel pump is not pumping gas or doing its job.
What else could be the source of the problem why it is not starting??
HELP please!
HELP please!
If your sure it is a fuel problem, check the connector under the van, behind the drivers seat they have been know to corrode causing the fuel pump not to work.
i checked the wire harness going to the fuel pump but it looks good and not corroded. the continuity is okay when i checked it. how much voltage should i get from those wires? other than the wires and fuel pump... what are the other issues that i should check, still not starting.. i still dont hear the fuel pump humming when i turn the keys.
more help please!
update with my problematic van...
i replaced the fuel pump again with an original chevy part because one mechanic told me to do so. but the problem was not solved. it started though for a couple of minutes but died. i noticed that the pump is intermitently pumping gas that's why the engine die after few minutes. i ruled out that the pump is not the problem, but a device that gives signal to the fuel pump to pump gas. my question now is.. what device is it?? is it the EGR or the PCM as what i saw in some forum.
this is a challenge for me.. but i need someone to HELP to pinpoint the real culprit!!.
PLEASE HELP!!!
PLEASE HELP!!!
Hi grejohn
I'm new to this forum, and got into because I have the same problem with my Venture 97, 5 diferent mechanics have gotten their hands into the motor and the problem still remains, all of them concluded that the ECU got a failure, so went to the autoparts store and ordered one, after being installed the problem remains, so I wonder if you got yours fixed already and what was the solution to your problem, it's posible the same case I'm in front of.
thanks for any advice
Hi grejohn
Now my tail light is not working... and it's a electrical wiring issue. Don't know where to trace the problem.
Hope you can fix yours.
distraction3345
December 18th, 2006 7:05 AM
