Venture 1997-2005
Platform: U-Body
Two DTCs I need help with.
Old August 1st, 2014, 4:21 PM
basslover1's Avatar
Default Two DTCs I need help with.
Hello,
Hopefully you fine people can help me out here. My mom's 2002 Venture (3.4L) has two DTCs stored, I had them read at Autozone. The first one is P0442, commonly the "I forgot to tighten the gas cap all the way," code. Now, she doesn't pump gas, period (let's not go there, please ), I do. I'm certain I always tighten it correctly but to be safe I went out and took it off and tightened it again. However, is there anything else that could cause this?
Second is P1189, something to do with the oil pressure switch it self. She hasn't mentioned anything about a stop driving now light, so I'm pretty sure it's just the switch but I'm not sure.
I'm sure these are basic questions for Chevy aficionados, but I don't know a single thing about GM vehicles, I'm a VW owner . Regardless, I'd appreciate any help in this matter.
Thank you!
Old August 1st, 2014, 8:39 PM
if you have a hard time filling the tank and an evap dtc; its possible the evap vent solenoid is nfg. the tank must vent air out this passage during refueling. If its clogged or the valve is stuck closed; no air out =no fuel in/slow filling.
Old August 2nd, 2014, 4:20 PM
basslover1's Avatar
Thank you for the response. Now that I think about it, when filling the tank I often have to search for a "sweet spot" so the overflow shutoff on the pump wont constantly kick in. However, since she's owned it, it has been a bit of a pain to put fuel in it, so maybe it's gotten worse lately but it's always functioned similarly so I just never noticed it get worse.
Old September 18th, 2014, 2:59 AM
green_lou's Avatar
Smile Suggest tool
Originally Posted by basslover1
Hello,
Thank you!
What tool you use to diagnostic tools? It doesn't show you trouble codes meaning?
I have one MG T2, it can do well.
cham88
Silverado & Fullsize Pick-ups
January 30th, 2011 11:48 AM
DJ420
October 9th, 2009 2:03 PM
EvansBlue
April 18th, 2008 5:57 PM
Mcguinness
Intake, Forced Induction, & Exhaust
February 14th, 2008 7:00 PM
livingwill
July 22nd, 2006 4:44 PM
Quick Reply: Two DTCs I need help with.
