Chevrolet Silverado Air FIlter
For SaleAccessories
Description:
PG Engine Air FIlter PA5638 | Fits 2006 Chevrolet Silverado 3500, 2006-10 Silverado 2500 HD, 2007-10 Silverado 3500 HD, 2006 GMC Sierra 3500, 2006-10 Sierra 2500 HD, 2007-10 Sierra 3500 HD
Product Description
Premium Guard Air</b> Filters are engineered to meet, or exceed, OEM air filter requirements of up to 12,000 miles of engine air filtration protection from items such as dangerous particles. Premium Guard Air Filters provide up to 99% filtration efficiency of dangerous particles while limiting air restrictions to ensure optimal airflow to the engine which provides optimal engine performance.See what it fits:
- 2006-2010 Chevrolet Silverado 2500 HD 6.6L
- 2007 Chevrolet Silverado 2500 HD Classic 6.6L
- 2006 Chevrolet Silverado 3500 6.6L
- 2007 Chevrolet Silverado 3500 Classic 6.6L
- 2007-2010 Chevrolet Silverado 3500 HD 6.6L
- 2006-2010 GMC Sierra 2500 HD 6.6L
- 2007 GMC Sierra 2500 HD Classic 6.6L
- 2006 GMC Sierra 3500 6.6L
- 2007 GMC Sierra 3500 Classic 6.6L
- 2007-2010 GMC Sierra 3500 HD 6.6L
You can find out anything using this link = https://amzn.to/3OreExX
BUY NOW LINK CLICK = https://amzn.to/3OreExX
AMAZON
- Manufacturer = Premium Guard
- Brand = Premium Guard
- Item Weight = 3.09 pounds
- Product Dimensions = 9.3 x 9.3 x 6.5 inches
- Item model number = PA5638
- Is Discontinued By Manufacturer = No
- Manufacturer Part Number = PA5638
- OEM Part Number = 12082149, 15282462, 15918221, 25839611
- Engine Light Comes On: Many cars are equipped with an airflow sensor that sets off the check engine light.
- Visual Inspection: Premium Guard automotive air filters are white so you can see if they're dirty. Check the outside and inner layers of the filter paper for dust and debris.
- Reduced Fuel Economy: When engines get less oxygen, they consume more fuel. If you notice fuel economy going down, you may need to replace the air filter.
- Engine Misfiring: Restricted air supply results in unburnt fuel exiting the engine as soot residue. Soot accumulates on the spark plugs, which can cause the engine to misfire.
- Reduced Horsepower: Replacing the air filter can improve acceleration or horsepower. If your car doesn’t respond well or jerks when you step on the accelerator, the engine may not be receiving the air it needs to perform.
- Black Sooty Smoke or Flames: Poor air supply can result in fuel not burning completely during the combustion cycle. Unburnt fuel exits the car through the exhaust pipe, possibly resulting in smoke or flames.
- Driving conditions
- Dusty roads
- Humid climates
- Congested roads and heavy-traffic areas
Efficiency describes the volume of dirt and pollutants that an air filter prevents from entering an engine. High efficiency Premium Guard engine air filters trap up to 99 percent* of dirt/pollutants over the life of a filter.
Restriction of airflow measures the air flow that passes through the car filter into the engine. Our automotive air filters are designed to maximize the flow of clean air into the vehicle's engine, enhancing its power and performance.
Dust-holding capacity refers to the quantity (weight) of airborne pollutants captured throughout the life of the auto air filter. All Premium Guard air filters feature high dust-holding capacity for exceptional longevity and performance.
*Tested per ISO-5011
About this item
- SUPERIOR ENGINE PROTECTION -– Premium Guard Air Filters filter out 99% of incoming engine air to help extend the life of your engine.
- ENHANCED PERFORMANCE – High-capacity air filter media removes dangerous particles, improving engine performance and increasing engine efficiency.
- EASY TO INSTALL - Premium Guard Air Filters are engineered to fit perfectly inside your vehicle’s housing for quick and easy installation.
- Compatible with Chevrolet Silverado 2500 HD, Silverado 2500 HD Classic, Silverado 3500, Silverado 3500 Classic, Silverado 3500 HD, GMC Sierra 2500 HD, Sierra 2500 HD Classic, Sierra 3500, Sierra 3500 Classic, Sierra 3500 HD. Precisely designed, engineered, and tested to meet and exceed all GENERAL MOTORS OE air filter requirements.
- Replaces GENERAL MOTORS 12082149, 15282462, 15918221, 25839611 Air Filter. Always check fitment using the Vehicle Filter
THANK YOU
