350 vortec won’t crank
I have a 97 Chevy C1500 5.7L Vortec 350. The other day a friend wanted to put sea foam in my throttle body to clean out my motor. Shortly after the smoke cleared my truck died. Got it to start again and while driving it started to overhead then lost power, had a water leak somewhere in the back of the motor closest to the passenger side. I took plugs out and it spins fine, no liquid comes out, put plugs back in and it won’t crank. Filled radiator back up and not having a leak anywhere. No oil in water and no water in oil. Thoughts???
When the plugs were out, did you turn the engine over by hand, or with the starter?
Are you getting a click?
No click (starter solenoid not engaging) indicates electrical supply (circuit between solenoid and ignition switch).
A click but no crank indicates the starter motor or mechanical binding. If you’re getting a click, have a helper turn the key to crank and hold, then tap on the starter housing with a small hammer. If this causes the starter to engage, replace the starter.
Rednucleus (July 16th, 2020)
Ok update...
I checked my harmonic balancer and I can turn it both ways. So don’t believe it’s hydro locked. I was then told to charge my battery to make sure it’s charged good. Checked it with a multimeter, it was at 12.68V. Tried starting again and I am getting a very slow crank. I can literally see my fan slowly turn then stop then turn again. Had a buddy check the battery drop when I turned the key, he said it dropped to 4V. Ideas?
Ok update...
Had a lifetime warranty on my starter so I put the new one in it. Finally it starts but I have to keep my foot on the accelerator or else it dies. Also it is running very rough and overheating. Had water spraying from one of my hoses..
stephh
August 14th, 2015 9:12 AM
borden_hcc1775
July 3rd, 2011 5:01 PM
ix3oh3xi
August 30th, 2010 11:12 PM
