700R4 weird shifting problem!
Hello everyone!
I've had problems with my 1990 K1500 6.2 diesel with 700r4. The truck shifts from 1-2 and 2-3 nice, but on third gear the transmission shifts weirdly to "neutral". It's not right after the 3rd gear engages but when i'm going 50kmh/30mph it suddenly pops to neutral. Downshifting works fine. I've replaced the TV- cable and it should be adjusted correctly and i've replaced the governor also and changed the oil and filter. I guess the next part would be to check the clutches if they are burnt but the old ATF was bright pink, it didn't smell bad/burnt and the transmission didn't make any weird noises. ATF level is correct and there wasn't any major particles in the transmission oil pan. Do you guys have anything in mind to help me out with this problem?
Thanks to all!
Thanks to all!
Hello everyone!
Thanks to all!
Thanks to all!
simpsonracing
March 1st, 2014 9:03 PM
80skeys
March 22nd, 2013 10:51 AM
Mille Racer 69
10
November 27th, 2010 11:06 AM
