Bleeding Hydraulic Clutch?
So I installed a new clutch pack and then the master or slave cylinder went out. Clutch pressure plate was really weak so I suspect new pack caused extra pressure on master/slave and seals gave way. 1995 truck with original master/.salve.... Anyway, I have read that bleeding these are a real pain. Any suggestions would be appreciated.
Truck ran fine for a couple of months after pack installation. All was new except master/salve, and FW was resurfaced. My slave is external and not inside bellhousing. It has traditional fork.
Its just a matter of gravity bleed or bleeding it out with a pump.At the age of your Chevy, you might need a new M/C as well, but try bleeding it out first.
Crack the bleeder on the slave and allow to gravity bleed.
Test pedal - if it still feels like there’s air in the system, set fluid level to minimum and leave cap off, then remove the slave from its mount, hold it vertically so the line is on top, and slowly depress the piston until it’s fully retracted. This will force air back up to the MC and out the reservoir.
A helper to monitor the fluid level and air flow is useful but this can be done by yourself.
Mount slave cylinder and pump the clutch a few times - if it still feels like there’s air in the system, repeat the process.
The following 2 users liked this post by tank1949:
oilcanhenry (July 28th, 2021),
Rednucleus (July 28th, 2021)
rhinoman7
October 4th, 2019 8:39 PM
cxhxexvxy
August 18th, 2009 2:16 AM
