Bumper Adjustment
Bumper Adjustment
My 93 Chevy C1500 has the passenger side bumper sticks out farther than the drive side..can it be adjusted to bring closer to the body..the first pic shows how it sticks out
If you still need an answer…
The bumper mounting bolt holes (either on the frame or the bumper) should be elongated or oversized to allow for some adjustment.
You will likely have to loosen the driver side bolts to make adjustments to the passenger side.
For many of these trucks, a gap between the bumper and front trim is normal, so you may actually need to pull the driver side out to even the gap - it just depends on how much play there is in the mounting holes and/or if anything is bent.
mountainmanjoe (March 19th, 2024)
