Engine Timing
Old Dec 16, 2019 | 10:11 AM
Reconyx_01's Avatar
Default Engine Timing
I'm working on removing the Intake manifold on my 1994 k1500 5.7 and I'm trying to remove the distributor. Cylinder 1 needs to be set at tdc compression stroke from what I've read. The timing cover has some teeth so you can line up your timing mark, but it's got 4 teeth so I'm not sure which tooth to line up with. All help is much appreciated, thanks.
Old Dec 16, 2019 | 11:19 AM
If you don't move the engine at all with the distributor out, just put the distributor back in the exact same position as when you took it out. This way you don't have to worry about any timing marks.
Ronnie Herrera
Nov 26, 2017 5:11 PM
markfothebeast
Jul 24, 2014 7:38 PM
timmy7728
Oct 20, 2012 7:31 PM
cduarte1982
K5 Blazer
May 22, 2010 6:26 PM
definity78
Sep 3, 2008 4:31 AM
