I need help
I need help
I have a 1989 chevy silverado 5.7 tbi. The I'm having hesitation problem mostly when I try to drive it but some times in idle. I have no service light on so the truck isn't giving me any codes. The problem that I was I lost my spark. So I replaced both coil ignition modular and the ignition modular. Truck started first crank. I have replaced my spark plugs and wires. My timing seemed to be 180 degrees off. Now im top dead center. I have just placed the fuel filter. Took the truck out for test drive. Was driving 30 mph. She seemed pretty good but at times she was hesitating but not as bad. Can you give me some other leads
So many possible causes.. check out this link describing similar symptoms. My gut tells me to lean toward an intermittent electrical short - a wire where the insulation has worn thru.
https://www.chevytalk.org/fusionbb/s...hp?tid/304236/
Firefox64
March 27th, 2016 5:11 PM
mfre111
June 2nd, 2012 9:46 PM
monteash
February 6th, 2011 7:14 PM
