Left caliper issue 89 Silverado
Changed out brake hoses, master cyl., proportional valve, calipers, pads,& properly bled system.. but still truck pulls hard to right.. changed brake hoses & calipers twice,
please advise!!.. whole system changed out
If it pulls either something was not done right with brake repairs or something is bad in suspension. I don’t know your experience in brake work but sometimes it’s not easy to get brakes bled properly or possibly something installed wrong. Eg. I remember a thread recently where someone accidentally installed wrong caliper on a side and bleeder was at bottom so even though it appeared to bleed properly their was air at top of caliper. Not sure how to help other than to say check again and check suspension. Good luck
Truck pulls to the right after caliper changed
Found out that the parts store sold me one caliper for a truck with heavy duty suspension & the other for a standard suspension... THAT. Is what caused the issue to arise... make sure you check the exact type of calipers that you get across the counter.. not all parts guys are knowledgeable!!
Rupe1989
February 23rd, 2021 11:41 AM
