Notices
No crank
Old June 16th, 2024, 1:01 PM
  #11
Jboc1974's Avatar
Ran a 10 awg wire from batt pos to starter side pos. Turns over just fine. I'm not getting 12 v at solenoid switch.
Old June 16th, 2024, 2:13 PM
  #12
So according to the chart, there's a fault in your starter positive cable .
Do NOT replace it with 10AWG wire.
Old June 16th, 2024, 5:06 PM
  #13
Jboc1974's Avatar
I tested the positive batt cable with an ohm meter. The cable itself is good. I've ordered an ignition starter switch. Seems like I've gone through everything else.
Old June 16th, 2024, 5:13 PM
  #14
bad connections then? Bottom line is not enough current is getting from the battery to the starter. Or your meter is not correct.
Old June 16th, 2024, 5:28 PM
  #15
Jboc1974's Avatar
I've got 12.5 v at the battery side of the starter, but when the key is turned there is only 2 to 4 v at the solenoid ignition wire. I've been pretty meticulous about all my cables and food clean connections.
Old June 16th, 2024, 6:26 PM
  #16
I'm sure you were meticulous. But this confirms the diagnosis:
and also shows the solenoid is fine.
Rednucleus (June 16th, 2024)
Old June 16th, 2024, 11:14 PM
  #17
By the way you can't measure ohms on a live circuit
tampaviking
May 1st, 2023 10:36 AM
Thatoneguy Lol
May 23rd, 2020 6:59 AM
stratos934
May 10th, 2019 12:38 PM
L1NK1NP4RK
June 3rd, 2012 10:46 AM
kathedi
January 2nd, 2007 9:14 PM
Quick Reply: No crank
