Rear end swap
https://cimg9.ibsrv.net/gimg/chevrol...3b9fb63f0d.jpg
https://cimg0.ibsrv.net/gimg/chevrol...bc61aae2fc.jpg Hello folks. My name is Rick. I have a 93 chevy gmt400 standard cab short bed step side. Sadly it has a 4.3 v6. Auto 2wd. thus, I bought 93 gmc big block suburban with the 4L80E Tranny. 14 bolt SF 2wd rear end with 8 lug wheels. I need your help to find out if I can put that rear end in my 3/4 ton suburban to my 1/2 ton truck? Both are 2wd. since same era I assume I can use whole drive train and suspension and wheels as well. 3/4 ton spindles will swap and have a bigger rodar and dual piston calipers. I think it will be a fun stomping the neighborhood truck. |
Believe the width is the same on all 2wd. 4wd is different. You will need a conversion u joint and the proportioning valve from the 3/4ton.
Rear end swap
Originally Posted by burnhedge
(Post 370760)
if I'm using the rear end and bigger Tranny from the suburban I shouldnt need the special u joint. I can see needing the proportioning valve. I just ran across a posi center section setup from a 2wd 14 bolt rear end. C clip type. From a 1989 square body truck. https://cimg6.ibsrv.net/gimg/chevrol...9b1a028f0c.jpg |
ive collected u joint information for the 73-87 chevys and their conversion numbers.
Universal joint conversion part numbers im not sure if it will help you but has the measurements and part numbers |
