Rear end swap
Old Feb 18, 2019 | 1:59 AM
rick Long's Avatar
Default Rear end swap
Hello folks. My name is Rick.
I have a 93 chevy gmt400 standard cab short bed step side. Sadly it has a 4.3 v6. Auto 2wd.
thus, I bought 93 gmc big block suburban with the 4L80E Tranny. 14 bolt SF 2wd rear end with 8 lug wheels.
I need your help to find out if I can put that rear end in my 3/4 ton suburban to my 1/2 ton truck? Both are 2wd.
since same era I assume I can use whole drive train and suspension and wheels as well. 3/4 ton spindles will swap and have a bigger rodar and dual piston calipers.
I think it will be a fun stomping the neighborhood truck.
Old Feb 18, 2019 | 2:37 AM
burnhedge's Avatar
Believe the width is the same on all 2wd. 4wd is different. You will need a conversion u joint and the proportioning valve from the 3/4ton.
Old Feb 18, 2019 | 1:33 PM
rick Long's Avatar
if I'm using the rear end and bigger Tranny from the suburban
I shouldnt need the special u joint. I can see needing the proportioning valve.
I just ran across a posi center section setup from a 2wd 14 bolt rear end. C clip type. From a 1989 square body truck.
Old Feb 23, 2019 | 8:49 AM
Irish_alley's Avatar
I'm here for the party
ive collected u joint information for the 73-87 chevys and their conversion numbers.
Universal joint conversion part numbers
im not sure if it will help you but has the measurements and part numbers
