Window weather strip install
Changing out my original window weather strip on my 1993 C1500 and need some advice. Do you have to remove the mirror or does this piece just lay in the channel? The replacement piece is long enough to go behind the mirror but not sure how to remove the mirror mounting plate if necessary, thanks.
Yes I think it does. To loosen or remove the mirror, on the inside there is triangle piece of trim right behind the mirror, grab hold and pull it straight out, hopefully not breaking the replaceable plastic clip or "christmas tree" that holds it on. You may have to remove the inner door panel too, been a while and I'm not sure. Anyway once you have that off there is a piece of black/gray foam filling a hole there, pull it out. Behind it you will see three 10mm nuts that hold the mirror on, loosen them a bit and you should be able to change the weatherstrip. BTW where did you buy new strips?
Great question - just checked my 93 Suburban & surprised to see it goes under the mirror trim. When I roll the window down, I can easily slide the trim strip back & forth; and am confident I could slide a new one in w/o having to remove the mirror. I want to replace these as well.
Rednucleus (October 1st, 2020)
hobbsron
2007 - 2013 (GMT900)
February 21st, 2017 4:08 PM
chengdave2003
June 25th, 2016 4:00 PM
wink1944
March 16th, 2013 8:54 AM
