Wiper Issues, Bad Control Module?
I've noticed the wiper arms don't appear to sit in the correct position, or return to the same position. The wipers also don't always actuate when I turn them on, and when they do work the path seems erratic. The passenger arm will hit the plastic cowl and the driver's arm will have the top inch or two of the blade extend past the windshield. I figured the linkage bushings were worn out and replaced them, but the issue still persists. Could this be a wiper control module issue, a motor issue, or a combination of issues? I replaced the wiper control module on my '98 Tahoe because the wipers intermittently worked, but never had the erratic motion.
Check the back of your pulse board for cracks in the soldering. If it looks like this it's probably your pulse board.
you could resolder it but I think it's a cheap part.
Chris94 (June 13th, 2020)
The pulse board was bad, no apparent cracks in the solder, but one of the contact pads was ground down to almost nothing. Do these have a seal between the housing and cover? There wasn't one when I pulled mine, and the inside was noticeably dusty. I had forgotten I pulled one of these from a junk yard a few years ago and had it in a box, tossed that one in and the wipers work, and the motion isn't erratic anymore. The driver's wiper arm still extends past the windshield, so I attempted to adjust the linkage arm, but it's already maxed out. The linkage arms definitely felt like they had excess play at the wiper motor, so I'll replace everything at some point. The wipers work, so I'm not overly concerned.
Chris94 (June 22nd, 2020)
The control module was a recall about 20 years ago. Funny, I had a 92 Silverado and it met every criteria for the recall, but when I called they said my truck wasn't part of the recall. So I had to spring for the new module.
Thanks y'all. While driving in the rain today I paid closer attention to the wiper arm movement. My wiper blades swing down a good 1-2 inches, then up across the windshield. I'm wondering if this board is defective too.
If they’re stopping below the windshield, remove the arms from the linkage and re-align them in the correct stopped position.
Well I assume the windshield wiper motor is just a round disc with a hookup point on it. So if it goes down first then it hasn't finished it's rotation and something is not aligned correct. Sounds like you just need to do a good calibration.
no idea if this works for your model but maybe it helps
