2002 4L60E TCC locking and unlocking
I'll try to explain the best I can and hopefully someone can point me in the right direction. I've looked all around and haven't found a good answer yet. Between 40-60mph and average cruising RPM the torque converter seems to be locking and unlocking rapidly. I can give it more gas or let off and it'll stop or barely hit the brake just enough to unlock the TCC (which I'm thinking means the TCC is fine). I haven't had the truck long so not sure of it's history but it looks like it recently had a new tranny put in. So far I have replaced plugs, wires, and all 5 solenoids in the transmission but none of that helped. I was thinking of clearing the tap values (not sure it was done when trans was replaced) to see if that helps but not sure if it could mess anything up. I have access to a Maxisys scan tool that can clear the values but didn't know if I should.Hoping there's a chevy GURU out there that knows his stuff.
Thanks
Thanks
