2004 Chevy 2500hd 6.0L having problems!! Help!!
Old Apr 6, 2009 | 6:20 PM
  #11
robo_1_2_1's Avatar
so that didnt work either. im giving up the truck is goin to a mechanic tomorrow. this truck is for now but will be fixed right before being sold.
Old Apr 6, 2009 | 7:11 PM
  #12
98white5.0's Avatar
Don't give up on it. Sometimes it just takes someone else lookin at it and doin the work for you. Just wait. After it's fixed, you will love the truck again...Or if you already have your mind set, no one can change your mind. Just sell it.
Old Jan 4, 2011 | 9:08 PM
  #13
scress's Avatar
I have a 04 2500HD 6.0 and just went through the same problem does it show a knock code if so change the knock sensors or check fuel pressure should be 55-61lbs
Old Jan 5, 2011 | 12:54 AM
  #14
CJ_Tiz's Avatar
I had the codes in my 04 6.0 and it was the MAF sensor. I forgot to hook it back up when I cleaned my K&N. It did the exact same thing your describing. Follow the MAF wires... could be a break or bad ground or some corrosion. One way is to read out the plug for continuity.
Old Jan 30, 2016 | 10:27 PM
  #15
Ronelizondo's Avatar
Default Help Locating Crankshaft sensor
I need help locating the crankshaft position sensor on my 2004 Silverado 2500hd, please help
Old Feb 12, 2016 | 7:42 AM
  #16
lex2500hd's Avatar
I seen a video on you tube and it was a ground cable on the air flow that was not all the way in .
Old Mar 16, 2016 | 5:20 PM
  #17
tawas23's Avatar
My truck was doing the same issues but I changed my knock sensors and gasket with updated teal green and ACdelco knock sensors and harness then replaced two 02 sensors that were bad testing heating element with multimeter showed was bad heating element on one when I changed my plugs there was a small iridium tip broke off I switched to platinum just out of the box and issues went away also my plug wires were dried up and one came apart in my hand when removing spark plugs cleared codes with OBD reader then I took off battery terminal positive and negative let it sit overnight and codes went away also I used seafome half can into gas tank and finally issue went away just a thought.. water in gas is very common causing all kinds of issues..hope this helps
Old May 11, 2019 | 2:27 PM
  #18
dpittman7's Avatar
o2 sensor ( upstream)
m_mek
19
May 22, 2023 10:57 AM
sweetiedee333
Jan 12, 2013 12:37 PM
ozrenee
HHR
Jan 4, 2012 7:36 PM
WhiteZ28
Camaro
Mar 18, 2010 10:09 PM
tom5170
21
Mar 15, 2010 8:06 PM
