Notices
60 mph shaking
Old July 5th, 2010, 9:23 AM
  #11
larryboy58's Avatar
No i did not recieve anything, they told me the tires were ok and that was it.
Old July 9th, 2010, 7:20 PM
  #12
larryboy58's Avatar
Today i rotated the tires back to front. Seemed to be a little better but I have not driven it a lot to be sure.
Old July 10th, 2010, 8:02 PM
  #13
desrtrat's Avatar
if it has had this since new, ether a front end issue, or bad rim(s). have you ever needed a brakes replaced in it yet?..sorry i can't be more help, at this point we're just shooting in the dark..
good luck
Old July 10th, 2010, 9:06 PM
  #14
Professional Mechanic
MDTAHOE's Avatar
If it change it at all then the problem is definitely in the wheels and tires.
Old August 8th, 2010, 6:31 PM
  #15
2wd-K5's Avatar
Originally Posted by MDTAHOE
Drive shafts usually only cause a vibration when there is load on them. By turning the engine off you have eliminated the load on the shaft. A drive shaft vibration would be very fast because the diameter of the shaft is small. It would also change with RPM
not if the universal joints are shot
Old August 14th, 2010, 1:32 AM
  #16
2wd-K5's Avatar
it could be the tires too, they do come with defects from the manufacurers once in a while
Old May 30th, 2023, 1:26 PM
  #17
gmc1500ninetoe's Avatar
Default Speed Wobble 1500 GMC 2005
That is typical tire vibration. By turning it off you have eliminated the load on the drive line and engine. It could also have a bad wheel. You need to have the wheels Road Forced and balanced on the Hunter 9700. Google road force and or Hunter 9700 to get more info on it.
no did the road force balance dose not solve problem. Tires most likely. Or rack and pinion. I am still trying to resolve this issue. Do not use aftermarket rack and pinion. That will not work OEM only. Good luck finding one.
malia249
Camaro
September 29th, 2015 8:03 PM
ChevyTruck55
February 1st, 2015 3:49 PM
MEC407
October 28th, 2008 6:01 PM
Outcastz89
November 15th, 2007 12:21 AM
Fishheads
March 12th, 2007 8:36 PM
Quick Reply: 60 mph shaking
