Camshaft Position Sensor Code PO342 issue
Old Sep 9, 2016 | 12:10 PM
dtrust68's Avatar
Default Camshaft Position Sensor Code PO342 issue
i changed my Camshaft position sensor in my 2005 chevy silverado. i also changed the starter. but now its throwing the low voltage/circuit PO342 code. would the Camshaft sensor maybe not seated properly or whats going on now? truck when on runs perfect. started perfect for a week with check engine on and yesterday it had trouble starting again. what could it be? battery is great. starter is new. my only thing im thinking is it not being seated properly so it could be off kilter and not getting good voltage. any help would be appreciated. Thanks
FYI all wires look great and plugs..
SOLVED...the new camshaft position sensor was bad..replacement fixed the issue
