Center Link replacement?
Just curious if anyone has had to replace a center link on Silverado 1500. It doesn't seem like something that can "wear out" really.
Anything can wear out if not properly lubricated.
Originally Posted by oldchevy
(Post 359721)
There are the joints where it connects to the other components.
(Post 359728)
Anyway... as near as I can tell, the center link is a solid piece of steel with holes for the idler, pitman, and inner tie rods. So I would think it would be unusual to need it replaced. I am replacing most of the steering including the gear box, idler arm with bracket, pitman arm, as well as inner and outer tie rods. I can spend another $100 (along with several more hours of labor) to replace the center link but I don't really know if it is necessary.
In your case you are right, but not all center links have 4 holes. Some have ball joints on the ends.
