Center Link replacement?
Old Jul 18, 2018 | 6:12 AM
Dustinfox's Avatar
Default Center Link replacement?
Just curious if anyone has had to replace a center link on Silverado 1500. It doesn't seem like something that can "wear out" really.
Old Jul 18, 2018 | 9:10 AM
Anything can wear out if not properly lubricated.
Old Jul 18, 2018 | 9:36 AM
Dustinfox's Avatar
Right but I don't think there are any moving parts on the center link are there?
Old Jul 18, 2018 | 10:25 AM
There are the joints where it connects to the other components.
Old Jul 18, 2018 | 12:53 PM
Dustinfox's Avatar
Which all have a tapered fit with their own bearings...
Old Jul 18, 2018 | 12:55 PM
Dustinfox's Avatar
Anyway... as near as I can tell, the center link is a solid piece of steel with holes for the idler, pitman, and inner tie rods. So I would think it would be unusual to need it replaced. I am replacing most of the steering including the gear box, idler arm with bracket, pitman arm, as well as inner and outer tie rods. I can spend another $100 (along with several more hours of labor) to replace the center link but I don't really know if it is necessary.
Old Jul 18, 2018 | 1:31 PM
In your case you are right, but not all center links have 4 holes. Some have ball joints on the ends.
