Key fob programming issue..... I've searched
I've searched and searched but apparently no one has ever had the problem I am with my 2000 silverado LS. The keyless entry doesn't work. I have bought a new remote and I have the original remote.
I tried and tried the programming method starting with holding the unlock button down and cycling the key twice. That never worked so I kept researching. I found info somewhere with programming instructions saying to hold the high beam on high in place of holding the unlock button. Using that method everything worked exactly as all of the instructions said....... Except for the actual fob working the locks.
It seems the system recognized the key fob since after holding down the lock/unlock for 30 or so seconds the locks cycled. But after that both key fobs do nothing. All of my research and nothing addresses this issue.
The only thing I wonder about is at least the driver's door on the truck is not original to the since the VIN on the door doesn't match the VIN on the truck. Unless the door is programmed to the BCM and their is some issue with that i wouldn't think that would be the case. The power lock should just be a motor.
Any help would be much appreciated thanks.
you can go to any shop that have a decent scan tool and they can add the fobs with the scan tool. they will probably charge you 1/2hour labour. if it doesn't work with the scan tool...it may be a fob problem.
Thanks, I might have to take it somewhere if I can't get it figured out. If I didn't still have the original fob that was programming the same as the new one I might think it could be the wrong fob.
Your situation is puzzling though. I've never heard about or seen your particular situation. I wonder if there is a signal issue of some sort like the antenna is damaged or something, But I couldn't even tell you where the antenna for the stock system would be, if there even is one.
Yeah I saw that on someone's post before and pulled the instrument cluster out to unplug it but it looks like I'd have to pull a large part of the dashboard off to get to it. I did disconnected the battery for an hour hoping it might fix it but it didn't.
