My VERY first post here! Im looking to do a 4.8 to 6.0 engine swap! Is it worth it?
Thank you for opening my thread.
I am a BRAND new member here and this is my first ever post.
I live in the California BayArea.
I have an 05 silverado 1500 2wd extended cab. I have a 4.8 with 240k miles on her. I did intake, dual exaust, and pumped up PCM.
How difficult is to swap in the 6.0 and the larger tranny?
Im concerned about the $$$ to find a good and 6.0 and tranny.
AND to find a local shop I can trust that will do great work.
Am I looking at LEAST $6k to do this swap!?!??
good question, I would like to know also. When my 4.8 goes, if ever, I was going to drop in the 5.3; which is pretty much just engine and pcm programming. You probably could get some built 5.3 that would put out some decent hp numbers comparable to the 6l....but if you want the trans option the 6l may be the way to go.
the 6.0 goes into a different frame so I wonder if there are any mount changes. Visually, the mounts look the same but there may be slight location differences.
Thanks for your reply Tech2
yes, the 5.3 would be a HUGE upgrade over our 4.8. And there's a ****LOAD of them out there. But the 6.0 would be a HUGE upgrade over the 5.3.
from what I understand, the 4.8 and 6.0 use MOST of the same ****, except of course the tranny.
for me it all depends on the cost for the 6l swap. At some point just getting a 2500 truck with the better suspension, brakes, coolers towing capacity is more cost worthy.
I had a 06 2500hd...way better truck than any 1500.
the 6l did go into a 1500 frame on the ss option.
Tech,
Buying a wrecked 2500 and swapping everything is probably the way to go.
But what would you with the leftover truck?
And you're probably looking at $4-5k for a wrecked 2500.
I'm pretty sure Chevy made a 2005 1500 with the 6.0
Damn!! I didn't know they pumped up everything around the 6.0 in the SS.
This means there's ALOT more involved in the 4.8/6.0 swap now.
I'm thinking closer to $10k when all said and done
Engine swap versus upgrade
I had my 4.8L bored and stoked to a 6.27L (384 stroker kit) and it has performed awe some. Also had a Magneson Supercharger installed. Very reliable and stable.
