tire and rim sizes i can use for my truck
I have a Chevy silverado 06, 4 door, with a 4 inch lift, and im wonderin if anybody knows if i put 2 inch wheel spacers on then 33's duratrac tires on 18's with a -12 offset, will that work and not cause any rubbing on the wheel wells.
It depends on the 4" lift. I'd imagine it kicks the tires out some since most lifts do. If so then you could run the 33s and -12 offset and not rub but no spacers on the front. Run spacers on the rear though to even track width with the front
