Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX Why Don't Power Door Locks Work
Guide to diagnose trouble and recommended solutions.
2007 Silverado: disconnected battery, now won't crank
#12
2007 5.3 new body style. Its not the battery, I load tested it and everything checked out fine. If you have any ideas, I would really appreciate it. I have been searching for 3 days and this is the first I have seen that resembles my problems. I am really starting to get frustrated and getting worried that the mechanic is not real for sure what is going on either.
#16
Yeah that is the bad part, folks get there vehicle going and some never come back and update what did and didn't work... Im hoping they got it fixed and are on their vacation and when they get back she will update us....
Have you tried disconnecting the battery?
#18
Yes. That was one of the first things that I did, thinking that it would reset. I literally pulled every fuse and relay, whether it had anything to do with starting or not. Switched the crank/run relay with another good one, turned out I could actually hear the relay clicking when I turned the key on.
#20
..There was hella tricks to my uncles alarm.
There was the alarm going haywire and you had to lock and unlock the car doors like 3 times and the holding the alarm reset button and turning your engine on. This also happens if you're alarm was disconnected. You may have loose wires maybe.
