2008 silverado oem radio will not power on and no alarms sounds
My radio is a oem has xm subscription and cd player. It had been working fine till Sunday. It will not power on. I checked fuse under hood and on drivers side fuse. Fuse ok and power to fuse. Looking for idea on how to get it working. I am orginal owner and have never wired any accessories or other radio on pick up.
Thanks in advance. |
Originally Posted by Madeinusa
(Post 363054)
now turn signal and airbag error
Today check airbag went on briefly and turn signal flash on dash pulsates and different intervals. Turn signal with different cycle is all the time. It was like 2 short flashes then a long flash then a series of short flashes then long pause with no flash and so on. Outside turn signal lights are flashing normal even cycle even though dash is showing different.
Anybody have a plan of action. I was originally going to take dash apart this weekend get radio number and figure on replacing the radio with another factory radio. Now with the turn signal and airbag I was wondering if there is a something else wrong. |
Now it is all back working including radio
Anybody have any Ideas?
?,maybe unhook wire harness from radio,a short?worth a try,seeing how that was first to act up
(Post 363117)
Since it is all working I have decided to leave it alone for now. If it starts happening again I will dive into it. Since I just bought the pry tools to take dash apart maybe truck decided to act better.
No Radio ,No Alarms Answer
Hi there, I too am having the same problems with my 08 Silverado. The stereo will not turn on and the chimes like the blinker or key noises will not turn on. I've tried all the same things that you had. Hopefully you found your problem hopefully you can piunt me in the right direction? Thank you in advance
Originally Posted by dakota cesena
(Post 459835)
did you figure this out I am having same issue with my 08. I got it to work today for about 3 hours then it gave out again. |
About intermittent issues
I have on ‘07 Silverado and had similar issues that stemmed from corroded fuses and loose harness connections underneath the “Under hood” fuse panel . In total I had 6 fuses and 3 relays that had corroded / Intermittent connection issues . I found the fuses that looked good by doing a continuity on each fuse . And I found the relay issues with the relay bypass/test set I have .
As i was checking the fuses and relays I was also applying an anti corrosive compound ( Truck -Lite NYK 77) to each fuse stab and socket as well as the relays stabs and sockets And the harness connections underneath the fuse panel . After having done all this everything that was malfunctioning has worked ever since . It does take some time to complete but is well worth the investment in time . I used Q-tips to apply the compound . Best wishes and Luck , I hope this helps you both . |
