2013 6L80 Transmission swap ECM Flash?
I will be swapping out the transmission, as the fluid is completely burned and the torque converter shutters / slipping at low RPMs when locked up.
I hear the ECM will need to be re-flashed after the transmission is swapped. 1 - Is this a true statement? 2 - If so, what does the re-flash do? 3 - Can the truck be driven to the dealer to get flashed? |
Just swap the TCM inside the transmission. You will have to pull the pan and maybe drop the valve body…
